Низкая скорость по порту ADSL(от U-tel)
srs72rus
Сообщение srs72rus » 06 окт 2011, 01:37
у моего знакомого слишком низкая скорость по порту , вот логи и т.п.
Mode ADSL2+
Latency Interleave
Trellis Coding Enable
Status SHOWTIME.L0
Downstream Upstream
SNR Margin (dB) 39.4 36.9
Attenuation (dB) 7.5 5.0
Output Power (dBm) 8.5 6.0
Attainable Rate (Kbps) 21528 1259
Rate (Kbps) 512 253K
(number of bytes in DMT frame) 3 4
R (number of check bytes in RS code word) 8 16
S (RS code word size in DMT frame) 0.17 7.80
D (interleaver depth)968Delay (msec) 4.12 15.60
FEC 0 0
CRC 0 0
Total ES 0 26
Total SES 0 3
Total UAS 0 52278
46> Jan 1 00:00:09 1970 syslogd started
<8> Jan 1 00:00:15 boa[92]: Boa/0.93.15 started
<14> Jan 1 00:00:32 syslog: spppd: ppp0: PPPoE AC system error: AC: Cannot open PPPoE session.
<8> Jan 1 00:00:38 boa[92]: DSL Link up
<14> Jan 1 00:00:49 syslog: mib_chain_update: PPPOE_SESSION_TBL on entry 0
<14> Jan 1 00:00:49 syslog: spppd: ppp0: AC MAC address 00:18:18:ED:7F:6C
<14> Jan 1 00:00:49 syslog: spppd: ppp0: PPPoE Session ID 58341
<14> Jan 1 00:00:49 syslog: spppd: ppp0: Authentication(CHAP) success
<14> Jan 1 00:00:49 syslog: spppd: ppp0: IP address 188.17.120.132
<14> Jan 1 00:00:49 syslog: spppd: ppp0: gateway 89.204.26.254
<14> Jan 1 00:00:49 syslog: spppd: route add default ppp0
<14> Jan 1 00:00:49 syslog: spppd: ppp0: Primary DNS 83.136.112.246
<14> Jan 1 00:00:49 syslog: spppd: ppp0: Secondary DNS 80.71.208.209
<14> Jan 1 00:00:49 syslog: mib_chain_clear: ATM_VC_TBL
<14> Jan 1 00:00:49 syslog: mib_chain_clear: ACC_TBL
<14> Jan 1 00:00:49 syslog: mib_chain_clear: AUTO_PVC_SEARCH_TBL
<14> Jan 1 00:00:49 syslog: mib_chain_clear: PPPOE_SESSION_TBL
<14> Jan 1 00:00:49 syslog: mib_chain_add: ATM_VC_TBL on entry 0
<14> Jan 1 00:00:49 syslog: mib_chain_add: ACC_TBL on entry 0
<14> Jan 1 00:00:49 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 0
<14> Jan 1 00:00:49 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 1
<14> Jan 1 00:00:49 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 2
<14> Jan 1 00:00:49 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 3
<14> Jan 1 00:00:49 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 4
<14> Jan 1 00:00:49 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 5
<14> Jan 1 00:00:49 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 6
<14> Jan 1 00:00:49 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 7
<14> Jan 1 00:00:49 syslog: mib_chain_add: PPPOE_SESSION_TBL on entry 0
<14> Jan 1 00:00:52 syslog: mib_chain_clear: ATM_VC_TBL
<14> Jan 1 00:00:52 syslog: mib_chain_clear: ACC_TBL
<14> Jan 1 00:00:52 syslog: mib_chain_clear: AUTO_PVC_SEARCH_TBL
<14> Jan 1 00:00:52 syslog: mib_chain_clear: PPPOE_SESSION_TBL
<14> Jan 1 00:00:52 syslog: mib_chain_add: ATM_VC_TBL on entry 0
<14> Jan 1 00:00:52 syslog: mib_chain_add: ACC_TBL on entry 0
<14> Jan 1 00:00:52 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 0
<14> Jan 1 00:00:52 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 1
<14> Jan 1 00:00:52 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 2
<14> Jan 1 00:00:52 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 3
<14> Jan 1 00:00:52 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 4
<14> Jan 1 00:00:52 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 5
<14> Jan 1 00:00:52 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 6
<14> Jan 1 00:00:52 syslog: mib_chain_add: AUTO_PVC_SEARCH_TBL on entry 7
<14> Jan 1 00:00:52 syslog: mib_chain_add: PPPOE_SESSION_TBL on entry 0
<14> Jan 1 00:00:52 syslog: mib_chain_update: PPPOE_SESSION_TBL on entry 0
<80> Jan 1 00:01:00 boa[92]: Authentication successful for admin from 192.168.1.3
в чем может быть проблема :? на форумах молчат , тех поддержка тоже( , решил обратиться сюда , может здесь есть понимающие
карренавод
Сообщение карренавод » 06 окт 2011, 03:05
Похоже линия в отличном состоянии. Downstream/Upstream: 512/253Kbps. Скорость видимо ограничена на порту мультиплексора.
reged
Сообщение reged » 06 окт 2011, 09:49
srs72rus напиши сюда
CJIOH
Добломан
Сообщение CJIOH » 06 окт 2011, 09:57
О, еще одна жертва Ю-тела. Точно знаю, что скорость могут и меняют, в сторону уменьшения/увеличения (если по знакомству) именно в ю-теле. У друга такая-же беда была. Нашел человечка, который там работает, он ему сделал анлим на 4 на весь месяц, без потери скорости. Естественно за счет других пользователей. Так что вывод, или ищите знакомых или мучайте их саппорт. Удачи.
suum cuique
Предупреждения: 1
Сообщение aleksss_555 » 06 окт 2011, 10:02
srs72rus, не вникая в подробности, сидел както на Ютеле, завленная скорость 256 кБ, но чаще было отсутствие соединения чем постоянная связь, зато абан плата взималась как положено и равными суммами, тех поддержка в минуты обрыва была занята, когда же появлялось подключение к сети и дозванивался в тех.поддержку начинали лечить дежурными фразами-- Перезапустите модем, компьютер и прочее,
помучивщись 3 месяца, переключился на ДОМ.РУ, проблемм ни каких, абан плата чуть выше зато скорость 1 Мбит и соедеинение постоянное без обрывов и тех поддержка в случае чего отвечает постоянно
R82
Сообщение R82 » 06 окт 2011, 10:11
aleksss_555 писал(а):srs72rus, не вникая в подробности, сидел както на Ютеле, завленная скорость 256 кБ, но чаще было отсутствие соединения чем постоянная связь, зато абан плата взималась как положено и равными суммами, тех поддержка в минуты обрыва была занята, когда же появлялось подключение к сети и дозванивался в тех.поддержку начинали лечить дежурными фразами-- Перезапустите модем, компьютер и прочее,
помучивщись 3 месяца, переключился на ДОМ.РУ, проблемм ни каких, и соедеинение постоянное без обрывов и тех поддержка в случае чего отвечает постоянно
+1, один в один такая же ситуация у меня была. Ю-тел в топку :down:
reged
Сообщение reged » 06 окт 2011, 13:56
CJIOH, зачётная шутка :up:
srs72rus, у тебя под ником написано, что ты из Каскары. там есть ДОМРУ? у них вроде (судя по рекламе) нормальные мультиплексоры.
srs72rus
Сообщение srs72rus » 06 окт 2011, 21:32
reged, dom.ru к сожалению нет :( , попробую написать на НГР
Mauzer
Сообщение Mauzer » 06 окт 2011, 23:05
проблем в понижении скорости никогда не был, но было что при первоначальном подсоединении приходилось переподключать сам модем.
srs72rus
Сообщение srs72rus » 10 окт 2011, 17:53
reged, спасибо повысили , на НГР) , можно закрывать тему)
Kentyxa72
Сообщение Kentyxa72 » 30 окт 2011, 23:51
Ютел любит "побаловаться" со скоростью конечно
